Salta al contenuto principale
iMac wont boot up, just the apple screen shows. Can anyone help?
My iMac turns on and has the apple screen on with the boot up continually running. There is a little circle thing that indicates that it is trying to boot up. But nothing is happening. CAN ANYONE HELP ME???
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
much worse is relative - it's always bad when something like that happens
but i would do pretty much the same
- reset the iMac like this and that
if the iMac still won't boot
- use the instllerdisk and try to boot up. use the disk utility to check/repair permissions
a few more infos are here
Punteggio 2
2 Commenti:
great answer if the asker knows that those colored words are links to solutions. Also how to start up from the installer disk.
da
you're right richard - i didn't think about that. but here we go: you have to press and hold the C key your keyboard to start from the installer disk
da
Aggiungi la tua risposta
melisag247 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,817
