How can I change keyboard
Hello,
Does any body know if you can change de keyboard of MacBook Pro 15i,ch late 2013.
I have a qwerty one and want to change it to a azerty one.
thanks
Questa è una buona domanda?
Hello,
thanks
First you'll need to find the correct keyboard mapping: Go to your control panel and open the Keyboard control panel. Then click on the Input Sources menu, on the bottom left click on the + to add in your choice once you add it save it. For now make a print out of the screen so you know what each location needs to be.
Step 2: Now carefully lift the key caps off your key board as needed (if you are missing a given key you can order it from: TheBookYard). Follow this Vid How to take the Key Caps off.
Thanks for these reactions. I'm going to check these propositions.
Thanks.
Jan
Hi
I believe you can. I googled Replacing Keyboard Caps Macbook Pro 15 inch late 2013 and one of the first sites I was directed to was
http://www.thebookyard.com/parts_unibody...
You first have to identify the specific types of keys that you have
That page was or if you type in your serial # in the top left hand corner and then select key caps in the drop down menu it might identify them for you.
http://www.thebookyard.com/apple_keycaps...
Depending on the type of key that you have they provide a PDF instruction manual on removing and replacing. I don't know if this is the key type that you have but here is an example of one of the manuals
http://www.thebookyard.com/images/manual...
THey also sell the keys however they looked rather expensive. You can probably do that same search and find a set less expensive once you identify the type you have.
I hope this helps. I believe this is correct information, however I have never tried to do this before so hopefully this is good information.
Whenever I need to replace or repair something I always google it and usually you can come up with something that will help.
THat is how I first found this site.
Good Luck
Have a Blessed Day
Al
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 4,709
