half of replacement screen not working
I just installed a replacement screen, it is the same screen, and when I turned it on for the first time half of the screen works and the other half is gray. it is split vertically in the center. any suggestions?
Questa è una buona domanda?
3 Commenti
Thanks for your reply,
I reseated both ends of the LVDS cable. I Also reseated both the connections on the inverter. The one thing i did notice is every time i reboot, even without making any changes, the "faulty" half of my LCD panel does something different each time. For example, it will be gray once, the it will be black, or white with black lines or different colored lines (all vertical). Does this random behavior mean anything?
Thanks
da Kurt
If the LVDS cable is good and well seated at both ends and you get a normal video on an external monitor then your LCD panel is the culprit. If the screen is lightened then there's no problem with the inverter board and cable.
da lemerise
Did you get it to work? What did you do?
da mayer
