Is replacing the backlight possible?
My Apple 20" Cinema display (A1081) has become dimmer over the last couple of months. Brightness is turned all the way up and the whites are still grayish.
Is it possible to replace the backlight in this otherwise functional display?
Questa è una buona domanda?
9 Commenti
still no solution? teardown, replace, work log?
da Marco Schoch
The tubes are just not available any more. I think its time to get a new monitor.
da Dan
@danj Hi there. I have been looking for info on the CCFL lamps used by the aluminium cinema displays (I have a 23" A1082 that is not as bright as it used to be) and I can't seem to find any.
When you say "they are just not available any more" do you mean that they were a special type? I am asking because I contacted lcdparts.net and they said "Sorry, we do not have CCFL lamps for Apple A1081, A1802 & A1083".
What characteristics do they have that are so special and they can't just be replaced with any of the CCFL replacement lamps available in so many lengths and diameters from all these vendors?
Please excuse my ignorance as I do not know much about CCFL but what I have been learning about the eye's tristimulus response, standard illuminants, backlight spectral peaks and LCD filters has changed my mind from trying to find LED replacements to looking for replacement CCFL lamps.
Thanks in advance!
da myalbino
@myalbino - CCFL's are just not made any more ;-{
The world has moved on to LED's.
da Dan
I hear you. I though about replacing the lamps with 6 LED strips but the monitor might be too smart and start complaining about the inverter not being enabled blah blah then I have to work out the LED dimmer, power to the strips etc etc. Plus the monitor is a bit annoying to open more than once. Plus it is not edge lit and I do not know if the strips in the middle of the screen will be visible. So, I decided to try going the CCFL direction.
Do you by any chance know the make and model of the LCD panel used in the A1082? I am avoiding opening the screen if I can get the info. I might be able to get some lamps from ccflwarehouse.com
If it all fails I will have to get a BenQ PD2700q which I really like but I do not really need right now if I fix this.
da myalbino
Mostra altri 4 commenti
