Salta al contenuto principale
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 Domande Visualizza tutte
Can I Disconnect the Optical Drive without Errors in my iMac?
I have an old iMac EMC2133 with an optical drive that is failing. I don't need the optical drive.
Following your guide, I can remove or disconnect the optical drive. If I simply remove it or disconnect it, will the computer work properly? Or do I need to replace the drive.
Currently, the optical drive runs constantly, repeating the eject cycle over and over.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes - you can do that, you can leave the bay empty with no ill effect.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 1
Aggiungi la tua risposta
jacbrown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 65
