Salta al contenuto principale
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Backlight doesn't work after LCD replacement.
I had a cracked LCD screen. Prior to disconnecting the LCD cables the backlight worked fine. I replaced the screen but since then the backlight doesn't work. I confirmed the backlight cable and LVDS cable are securely attached. What are the possible causes?
Questa è una buona domanda?
Punteggio -1
1 Commento
Did u get this fixed ??
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Blown fuse/controller for the backlight. This is not a DIY repair unless you work with electronic component replacement on a regular basis. Logic board soldering requires special tools, solder & lots and lots of practice.
Follow the tag at right for more information.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
3 Commenti:
Is there a way to confirm this visually before taking it in?
da
Kimberly, if you have a multimeter you could check the fuse for continuity.
da
Where is the fuse?? Location
da
Check your backlight cable ... I installed mine the way the cable was positioned and best I got was black screen with faint apple symbol .....
But turns out I had it in backwards ... Was very awkward to flip cable and install bit that was it , try that just for !@#$% and giggles
Punteggio 1
Aggiungi la tua risposta
Kimberly sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 404
