Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
How to reset a forgotten password without itunes.
I have tried everything but every computer I use says that my iPhone can't be detected. I need a simple way to unlock my iPhone as soon as possible.
Questa è una buona domanda?
Punteggio 143
5 Commenti
how do I restore ipod and don't know the passcode?
da
My computer wont detect my iphone 4 and im not finding away to fix my disabled iphone
da
Hi how to reset the iphone was dis abled din connect to itunes and i dont know the apple id.,can i remove the apple id and make a new one?
da
Im trying to unlock my iphone se but everytime i try to look up ways to complete this task it requires money so can you help me to unlock my phone for free
da
My iPhone is not working because same problem me also my home button is not working and also volume buttons not working. How to solve it please tell answer my frnds
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Hi,
I think that the best way is to put iPhone in DFU mode, in that case you will lose all data and when you connect iPhone on iTunes he will make recovery and (if you had backup he will make restore)
Punteggio 62
4 Commenti:
you can just do recovery mode, thats easier, power off the phone and plug it in while holding down the home button....
da
iv tryed that it doesnt really work
da
Recovery Mode and DFU Mode , two ways work, and it's very easy, but you will all data in iDevice. But if you have iCloud, you can use Find My iPhone in iCloud, from where you can erase your device, then you can reset your iPhone without iTunes.
da
Is there also a way to reset the Code without resetting all data?
da
your iphone need to keep your device connected until the "Connect to iTunes" screen and then you uses usb calbe to connect to itunes and restore your factory settings . it work for me, hope this help your all out
Punteggio 4
1 Commento:
it dont work
da
Use an Unlocking Service
There are third-party services that offer unlocking services, but these are generally not recommended due to potential security risks and the possibility of voiding your warranty. However, if you're in a bind and trust the service, it could be an option.
Punteggio 0
Aggiungi la tua risposta
michelle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 18
Tutti i Tempi: 283,853
