Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
2375 Domande Visualizza tutte
How can bring an iPhone 4 back from the dead?
I'm looking to restore an iPhone 4 that has drowned in a pool. It only power on when docked or charged. I'm pretty sure the software still functions well so I thinking I should replace the logic board, battery, and power supply cables. The wireless antennas could probably be replaced as well. If there is anything else I need to know or if you have any tips you would like to provide I would very much appreciate it.
Questa è una buona domanda?
Punteggio -1
1 Commento:
the software will be the least of the problems since a restore will take care of that. Sounds like your are trying to replace everything. Always make sure that you only replace things that need to be replaced. With any water damage, you want to clean your phone properly first, then replace the battery and then reevaluate for any further damage.
da
Aggiungi un commento
2 Risposte
Start off with Replacing the battery and reconnecting and cleaning the power flex connection with appropriate alcohol solution would help - Then Try Charging via Wall Socket and Computer USB
After you can get it to stay on test a few of the parts such as : Cameras, Vibrator, Volume Buttons, Earpiece Speaker and Loudspeaker.
Punteggio 0
The "Logic board" IS your phone. The only way to replace it is with another phone. The only thin that was could be irrepairably dammaged is the screen. everything else can be disassembled, cleaned with alcohol, sprayed with brake-kleen, then blown dry with compressed air. The only phones(actually its the "logic board" that determines success here) I havent been able to recover by this method are those that 1)Got wet, 2)Were allowed to corrode, and 3)Suffered physical damage due to components being eaten away so that after cleaning they were simply not there any more. Get a jewlers loop and look at the size of the smallest components on the logic board. They look very important and you can fit at least 3 on the head of a pin.
Punteggio 0
Aggiungi la tua risposta
Faison sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 171
