Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
69 Domande Visualizza tutte
USB Connector Cable torn down
Hey guys,
I have made a disply replacement on my Lumia 920. Thanks for the tutorial. It works!
Unfortunately I torn down the USB Cable at the begin of the disassembly. I bought a new one. The same problem with the new one. In the moment when I am closing the case the cable is squeezed and then its torn down.
Is it possible to make a soldering or to use any glue?
Best regards
David
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi,
You can not use soldering option here unless you are willing to risk your device for soldering however you have to buy a new usb cable and connect it if you think you can not achieve that percision then take it to a local repair shop for fitting the case after plugging usb cable. Try to keep a steady hand while fitting if you give it a retry.
Good luck.
Punteggio 0
Commenti:
Hi,
thanks for your quick reply. OK I will try it a third time with a new usb cable. Hope not to squeeze the connector.
da
Aggiungi la tua risposta
David Obladen sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 364
