iMac Intel EMC 2428 won't start even after replacing power supply
I Installed a new power supply in my iMac Intel EMC 2428 or A1311 and it still won't power on. Is there a way for me to turning on my mac using a screw driver and jump the pin in the motherboard?
Questa è una buona domanda?
3 Commenti
I don't recommend poking around with screwdrivers.
da Dan
Can you tell us what the symptoms are in why you replaced the power supply and what your system is doing now with the new one. Is it reacting the same? Are the fans running and is the diagnostic LED lit? And beeps or bong sounds?
da Dan
I was online using surfing the net and the iMac just shutdown and won't start since. I replaced the power supply because i had a technician check it and he said it was a power supply issues but the fan doesn't run, it makes no sounds, i see no LED lit, no beeps, etc. But i remember you can start a computer by touching the pin on the motherboard. What do you suggest? And Thank you so much for replying to my problem.
da jtsurprise
