What is the correct surface mount fuse value for the LED.
Looks like I got hit with the magic drop of coffee. My MBPr backlight is off but the LCD data on the screen appears fine. Both external video ports also work. I have taken a look inside and noticed a tiny little drop of coffee on the bottom case near the video cable. there appears to be no other damage or corrosion. I have spot cleaned the area with rubbing alcohol with the battery unplugged. Although its still under warranty, It will take 7 days and I would likely be hit with a "water-damage" fee which exceeds $1200 on this machine. After much research and past experience I believe that this 2A 0402 fuse is blown and needs to be replaced, $6 for 10 LOL. Before I take it into my local tech for metering and replacement with his magical solder tweezers for surface mount components, I want to order the replacement fuses and have them with me.
Does anyone know the specs of the replacement fuse on this model. Thanks for any info and this awesome site over the years.
Update: Looks like Apple may have made this harder than it needs to be. The component may have been moved to the underside, cpu side, of the board. Any suggestions on location for testing.
BTW, what a beautiful computer inside and out!
Questa è una buona domanda?
