Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
Replaced screen and now phone doesn't power on?
Pretty simple, I replaced the screen on an iPhone 4S and now it will not power on or respond to hard reset or being plugged in. I do notice that after being plugged in for a minute or two, the logic board gets a little warm but still no sign of life. I've taken it apart to check and reseat the connectors three times now, I'm stumped.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Hi there,
have you tried a hard reset?
If not, here's how: http://www.wikihow.com/Hard-Reset-an-iPh...
Hope this fixes your issue.
Punteggio 0
1 Commento:
I mentioned in the question that it does not respond to a hard reset.
da
Examine the battery connector carefully. It's easy to break away from the logic board if you are less than gentle when disconnecting the battery.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 153
