Is there a replacable fuse?
I was using it & the screen went blank & the Sleep lght does not work but I can feel the Hard Drive spinning. Is there a fuse inside?
Questa è una buona domanda?
No fuse, but there is a lightbulb (backlight). That is fluorescent and like all fluorescents has a starter (inverter).
Connect to an external display If you see nothing there it's the GPU/VGC (logic board) but if it looks normal your problem is in the internal display chain. Possible failed parts: display data cable, inverter, backlight or LCD. Shine a light through the back of the screen if you faintly see the desktop that eliminates the cable and LCD and points to inverter or backlight.
If this answer is acceptable please remember to return and mark it.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 158
1 Commento
Seems like very good sound advice. I'll try it ths way. Thank You for Your time machead3.
da davej
