Battery connector broke off motherboard
I was taking apart my iPhone 4S 64g and when disconnecting the battery the connect that is on the motherboard broke lose from the motherboard can I fix this?
Questa è una buona domanda?
Ahh, you forgot to release the battery from the mounting before tearing the battery out.
I did exactly the same thing with an iPhone 4 just before the 4s was released.
In my case it actually tore the contacts from the board making it impossible to solder it back on.
I tried, and had mixed results with the phone working for a few minutes at a time at best but my story does not have a happy ending.
I ended up buying a new phone and giving away the 4 for spares in the end.
Depending on the damage done, there might be a chance you can solder a new connector on if you have a good soldering iron.
Replacement battery connectors can be obtained on eBay, I recall that's what I did.
I'm just hoping you didn't loose the contacts from the board like I did.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 940
Post an image of your damage with your question. That way, we can see what you see, and can give you a better answer.
da oldturkey03
