Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
iPod Doesn't Play Music or Video
This iPod charges, and syncs to iTunes. But when it is turned on, it displays a sad iPod icon. If it is turned on after that, it comes on normally, you can navigate through it. Yet, when you try to play music, the count stays at 0:00. I believe the headphone jack is okay because when inserting and removing headphones, the play/pause icons in the corner changed. When you try to fast forward in the song, it still does not play. Additionally, videos do not play, and the iPod freezes when you try to.
I've narrowed it down to either the hard drive or logic board? Has anyone experienced and repaired this problem? Thanks for your help.
Questa è una buona domanda?
Punteggio 2
7 Commenti
have you tried a reset and / or restore from itunes?
does anything else work (clock, stopwatch etc?)
da
Sounds like it functions, so not the logic board, sounds pretty much like an HD failure
da
Yes, I tried a reset and restore. With the advice and answers posted here, I will soon try to replace the hard drive and post an update after the repair. Thanks everyone for your help.
da
UPDATE: After the first teardown, the click wheel and the button stopped working properly. I replaced the hard drive, but still get a sad iPod logo. I can't navigate through the iPod to see if the first problem still exists. I will purchase a new click wheel and with the advice from an iFixit customer rep, a new hard drive cable. I'll replace the click wheel and click wheel button first. If the sad iPod still shows, I'll replace the hard drive cable. If it still exists, I'll have to purchase a logic board. More updates will follow as long as the repair endures.
da
Hey scott did you fix your ipod?
da
Mostra altri 2 commenti
Aggiungi un commento
3 Risposte
Soluzione Prescelta
This usually means that your hard drive has gone bad. I had a classic that had similar symptoms that replacing the hard drive fixed.
Punteggio 2
1 Commento:
With your confirming advice, Nat (Thank you!), I will try to replace it very soon. I will post an update after the repair.
da
ipod is dead, it does not turn on it does nothing, what could this be please.
Punteggio 0
1 Commento:
Try a new battery?
da
yae i had something like that and i fomat it from windows also you can use the disk utility in mac osx and rpair it if its not repair use earaze and then you must go to the itunes and restor it maby its work its sound the hard drive have problem or the data not readable
Punteggio -1
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 6,707
