Salta al contenuto principale
Si tratta della 6° replica di Iphone Apple, annunciata il 12 Settembre, 2012. La riparazione di questo dispositivo è del tutto simile a quella delle precedenti versioni di Iphone e richiede l'impiego di cacciaviti e strumenti di apertura. È disponbile con tecnologia GSM o CDMA, con 16,32, o 64 Gb di memoria, nei colori nero o bianco
3356 Domande Visualizza tutte
Home Button Clicks but doesn't work- ripped rubber
I replaced my screen by following the guide on iFixit. Everything worked perfectly except now my home button doesn't work. It clicks normally, but has no response on the phone. When I was replacing the screen, the rubber edge of one side of the button ripped off. The guide said explicitly to make sure this doesn't happen, but it was a really small part of the rubber. Is that little bit of rubber that tore off causing this problem?
Should I order a new button and replace my current one?
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Kit per Apple Watch
Screen and battery repairs just got easier.
Acquista ora
Kit per Apple Watch
Acquista ora
3 Risposte
Soluzione Prescelta
First go in and check the slot where the button locks into place on the inside of the phone.
Use the ifix guide for that model of phone to walk you to the home button replacement if you need to order a replacement flex cable there only a buck or two on ebay
Punteggio 1
I agree with the first answer.
I have found the home button to be notoriously unreliable on all iPhones and iPads
Cheers Paul
Punteggio 0
I agree with Gary, also to check the homebutton, you can disassemble the phone and bridge the homebutton receptor to see if it responds. This means having the phone on and disassembled at the same time.
On this image:
http://d3nevzfk7ii3be.cloudfront.net/igi...
Notice the two copperish things centered below the battery? Bridge those with something conductive, a screwdriver usually works and see if the phone responds. If it does replace the flex cable.
Punteggio 0
Aggiungi la tua risposta
bhkonig sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,080
