powers up, no chime and no display power-up
I can hear the sound of it getting powered but not any HD noise, i get no chime and the display is not lighting! Could it be a hard drive and display failure both at the same time?
Questa è una buona domanda?
7 Commenti
zoran, based on your serial number, these are your sepcs:"2.4 GHz Core 2 Duo (T8300)
Intro Date: February 26, 2008 Disc Date: October 14, 2008
Order No: MB133LL/A Model No: A1260 (EMC 2198)
Subfamily: Early 2008 Model ID: MacBookPro4,1
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 200 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
da oldturkey03
just to verify, are these the symptoms you have:"(no sleep light, no fan movement, no hard drive spin-up, no Caps Lock LED illumination when pressed, and no display illumination?
da oldturkey03
Sleep light is constantly on, fan is moving, no hard drive spin-up, no caps lock led illumination when pressed and there is no display illumination!
da genik
I got a cable (dvi to hdmi) to check the display on an lcd tv. Just to be safe,i first plugged it in an older laptop of mine (powerbook g4), just to be certain on what will i be expecting to see! But now i think i got more mixed up cause i can only see the PowerBooks desktop wall paper... is that right?
da genik
Guys, forget about the issue with the older laptop, it was just a matter of screen arrangement. I connected the dvi2hdmi cable to the MBPro model and there was nothing to display on the lcd tv. So what is the verdict now?
da genik
Mostra altri 2 commenti
