The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
598 Domande Visualizza tutte
phone will not power up battery contact broken and slightly corroded
Phone will not power up. Slightly corroded and one battery contact looks broken. I have a brand new Galaxy S3 so is there anyway to switch out parts in order to reach internal memory? Desperately need pictures that were not saved to Sd card.
Risposto! View the answer Anch'io ho questo problema
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
Sfoglia il Nostro Negozio
1 Risposta
Soluzione Prescelta
hcnevils, all those images and information is stored on the memory IC's that are soldered to your logic board. Not much of a chance to get to them for the DIY'er. Id try and fix the battery contact, clean the logic board with isopropyl alcohol and a soft brush. See if you can get it to work long enough to get to your files. Hope this helps, good luck.
Punteggio 1
Commenti:
How can I fix the battery contact? Thank you for your help....cleaned it up with alcohol but seems the salt has caused a lot of problems.
da
post an image of your damaged board so we can see what you see. Use this guide Adding images to an existing answer to help you with the images.
da
Aggiungi la tua risposta
hcnevils sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 432
