Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2519 Domande Visualizza tutte
iPhone 5 not charging or connecting to iTunes
So, i bought an iPhone 5 last week, the seller told me everything was working except the logic board. When i got it i did a soft reset and it booted up, it showed 10% battery. After the battery drained i tried to plug it to my computer and no response. Same with wall adapter. I replaced the dock connector and the battery and still no response. The phone boots up and functions perfectly but doesn't recognizes the lighting cable or any kind of power inlet. Any ideas what could be causing the problem? (I've heard something about the USB Power IC, but not sure about that). Thank you in advance!
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The logic board is the motherboard controlling the entire phone. Try Changing the lighting port and if that works, you are blessed.
Punteggio 1
2 Commenti:
Wisdom Banks, "replaced the dock connector" includes the lightning port
da
Thanks for your respond, it turned out it was the motherboard, I sold the iPhone and bought a new one. I did change the lightning and the battery with no luck.
da
Aggiungi la tua risposta
Luis Fondeur sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 778
