Salta al contenuto principale
Fix Your Stuff
Right to Repair
Parts & Tools
Il primo modello di iPhone (A1203) con 4, 8 o 16 GB di memoria interna e retro in alluminio. La riparazione potrebbe richiedere alcune saldature e una buona dose di forzature sui componenti.
287 Domande Visualizza tutte
Epoxy / glue for back case
The iPhone (2g) case is made of several aluminum parts that have been glued or epoxied together. The bit of aluminum that the head phone jack is screwed to came unglued from my case. Just wondering what would be the best stuff to use to reattach it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Fix-All Adhesive is a great all-purpose solvent glue and sealer. It seals and repairs almost any surface easily and quickly. http://www.supergluecorp.com/super-glue/... FixAll
Punteggio 1
I’m very far from the top of the page where you were discussing UltraDome. I have worked with epoxy resin. It yellows…I can live with that. Pretty much. But you really have to have a lot of things thought out very well beforehand or fixing it afterwards is a real DRAG!! and sometimes impossible.
http://www.parsonadhesives.com/partite-p...
Punteggio 0
Well i had used Epoxy Seam Sealers for the floor pan bonding in car, it works great. Hopefully it will solve your problem too.
Thanks for the post
Punteggio 0
Aggiungi la tua risposta
scampy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,852
