High Beams don't work, low beams do on 2000 Dodge Ram 1500?
The brights no longer work but the low beams do. I have checked fuses, replaced one of the bulbs, and tried out a new switch. What should I check next?
Questa è una buona domanda?
Andrew Hindman , check the relays in the fuse box next to the battery. It should be the "Quad" relay
The arrow shows the fuses for the headlights, but you said they are okay, so that leaves the relay, or a short/loose connector in the harness. Hope this helps, good luck.
cleaning the wire harness where it connects the the ecm (fcm) next to the fuse panel will fix this issue. once cleaned reinstall with dielectric gel
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 7,918
1 Commento
OK so I've check every fuse and relay but check this out fuse box next to battery where it shows quad you put a relay in the space there's no wiring going to that space what next I love my ram but this headlight issue seems to be a major dodge issue its just the older truck new ones to dodge should have to repair this issue my truck might be old but it was new when I bought it DODGE SHOULD BE RESPONSIBLE FOR ALL THESÈ ISSUE WE. PAYGOOD MONEY FOR THERE TRUCKS TO HAVE ISSUES LIKE NO HEADLIGHTS OR NO LOW BEAM OR NO HIGH BEAM ...BUT YOU TAKE IT TO THE DEALER THEY WELL CHARGE US UP THE PORT HOLE AND TELL YOU THEY COULDNT FIND THE ISSUE W T F
da Thomas T Susoeff jr
