Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
iPhone 3GS won't boot at all
My iPhone 3GS won't boot at all. I bought it off of ebay, and it was listed as water damaged. Only the water indicator in the dock connector was active, but the other one at that top of the phone was not active.
I took the phone apart, soaked it in alcohol, gently cleaned it with a toothbrush, and finished it off with CRC electrical contact cleaner. I even removed the logic board shielding during this procedure.
If there's a simple cable I can replace to get it working, I'd be happy to do so. The one cable coming out of the display that doesn't "click" in seems to be burned, or something like that. I've attached photos for reference.
I cleaned up the copper side of the cable, but the back side that appears to have a black dot - I can't clean that side. What cable is this, and is it causing my problems?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would try a dock connector seems like the battery's flat and the docks broke
Punteggio 1
2 Commenti:
Is there any way to repair the dock connector, rather than getting a new one? I already cleaned a good bit of gunk out of it, and it looks really clean at this point.
da
If the parts not going buy a replacement part it's so cheap
da
Aggiungi la tua risposta
Casey Friday sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 307
