a/c freon fill location 2005 ford focus
cannot locate the low side refill port
Questa è una buona domanda?
Eugene Scarbrough, The service valve is behind the wheel well cover on the front passenger side. Take a look on here for service and refill instructions. "the A/C system is under high pressure. Also, while R134a isn't as bad for the environment as the older R12, there is still a heavy fine for venting R134a into the atmosphere. You should never take apart your A/C system without proper training and refrigerant recovery equipment. Wear protective glasses at all times while servicing your A/C. Also, you will be working under or near the car while it is running. Hope this helps, good luck.
@oldturkey03 Congratulations on the milestone 300k just noticed your over
@jimfixer thanks appreciate it. Almost time to retire :-)
This is exactly where it is on mine.
@oldturkey03 - Congratulation also, You can't retire till after I do ;-)
@mayer darn mayer we'll be hanging out here forever. ;-)
Go to youtube.com , type in refill car air conditioner and watch the very helpful videos. Worked for me.
I'm sorry,you are wrong.The low side A/C port is behind the "inner fender"
of the right side or pass side.If you remove the "right front" tire and
fold back the "inner fender"from the front you will see the "accumulater"
and the low side port is easy to see on the top of the accumulater.A/C
gauges are needed to make sure the pressures are normal.Better yet let a
professional do it as you could causer more harm if you don't understand
and know what you are doing.
Dead on right info. AC just needed a little shot, back to ice old.
Harry Grace, sure sounds like the same place as mentioned in my original answer.
IS The Accumulator in the same place on Australian Ford Focus since there RHD ?
That's actually called the low-side liquid receiver to prevent liquid refrigerant* flowing back to the compressor - liquids can't be compressed.
*: It's called "refrigerant" - there's actually no such thing as "freon". Freon(TM) is a trade name of DuPont for it's line of halogenated hydrocarbon refrigerants.
Low side a/c port location directly in front of pass side back left small valve can't miss it well it is on the 2006 Titanium model !!!
is the low side charging port in the same place on a Australian Ford Focus RS model?
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 42
Tutti i Tempi: 72,001
2 Commenti
are we dealing with the European version or the north American version
da Jimfixer
It would be a little better to say; in front of the working linkage; on the right side of the vehicle.
da Chuck
