Salta al contenuto principale
Repair and disassembly guides for adapters of all kinds.
Battery Charger to hel test if it's a bad battery or a bad power jack
I do computer repair. I was wanting to know if they have a device that can charge any laptop battery externally. In my troubleshooting I want to make sure I'm not dealing with a bad power jack that's not charging the battery or not charging it right. I want an external device to determine if I'm just dealing with a bad battery that needs to be replaced.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Good question! Sorry no.
The problem here is each different LiOn battery requires a different charge cycle & connection just within the one manufactures collection of systems it sells (Apple alone is around 20 different batteries).
Punteggio 1
1 Commento:
The best way is to use a Ohm meter to check the connectivity, and a Volt meter to check the voltages of the circuit pathway.
da
Aggiungi la tua risposta
Dan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 38
Tutti i Tempi: 437
