No Backlight
I have the same issue (only difference being my friend fell on it while it was closed, no smashed screen), the last three digits of mine are W0H, greatly appreciate any info.
Questa è una buona domanda?
Yes it's a hardware issue most likely the backlight (or connection to it ) was damaged.
FWIW most replacement LCDs include the backlight. (Trying to replace just the backlight is a very advanced DIY) Replacing the entire LCD dissplay is a lot of work.. but not as finicky as try to do just the backlight.
If this Answer is helpful please remember to return and mark it Accepted.
Alright no problem, thanks very much for your help and advise!
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 626
3 Commenti
Do these specs look right:
Intro Date: October 24, 2006 Disc Date: June 5, 2007
Order No: MA610LL Model No: A1211 (EMC 2120)
Subfamily: Core 2 Duo/Late 2006 Model ID: MacBookPro2,2
Std RAM: 2 GB Std VRAM: 256 MB
Std Storage: 120 GB (5400 RPM) Std Optical: 6X DL "SuperDrive"
Complete MacBook Pro "Core 2 Duo" 2.33 15" Specs
da oldturkey03
What have you tried so far? Does an external monitor show a proper image?
da oldturkey03
Yeah that looks right. I have tried turning up the brightness, zap PRAM procedure, resetting the energy saving settings to try and trick it back into working and I have tried removing the battery, holding the power button then powering up. None have worked nor made it even flash.
It is still operational, screen still showing (very faintly) just no light. The external monitor is showing the image fine.
Is this more of a hardware issue?
da James Child
