In spin cycle machine is banging and making lots of noise
When machine arrives to spin cycle (last 7 minutes) machine is banging and making lots of noise
Questa è una buona domanda?
I'd bet the bearing.
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Or it could be like what happened to my washer and one of the tension springs just came off. They always leave the cheapest fix off the list don’t ya know.
The one I have does not have a belt it is a direct drive. I thought the stator and rotor are bad. There is a loud squeak coming from the rotor. I didn't see any play in the bearing.
How do I get to the drain pump to check if it's stopped up
Often this complaint is caused by a broken spider that connects the drive shaft to the drum itself. It is replaceable, but a pretty big job. If you can lift the drum up from inside more than a half inch or so, it will be the spider and not a bearing issue.
The problem is that the corrosives in the detergent weakens the aluminum spider and on the spin cycle it fails. The spider, due to corrosion is not weldable in any permanent way.
Always leave the door open a bit on front load washers so the inside drys out between loads. This will reduce the corrosive action. Letting it dry out will also keep bacteria from making the drum smell.
Good luck
BTW, I should have mentioned, this is for front loading washers only.
I'm replying to a 4year old post don't know if you will get this, every body saying it's outer tub bearing, even though I don't know what's going on I wasn't believing it. When I read your post, immediately I knew what the problem was and it explained a lot about why it was making that noise like something was inside tub
My washer does fine on all cycles except for towels. Why
I have a top loader and it bangs against the frame when washing, but does fine when spinning. Please help!!!
Related to what Jeff Weaver Said in the comments above (back in 2016), I did experiment the Spider arm failure on a similar Kenmore machine just last week.
The spider arm is the part that holds the drum to the bearings and motor. It’s made of a white “pot” metal.
This metal does not like cold water, since it make the cheap detergents stick on it, which causes premature corrosion. (High end detergents might help a bit I guess).
Corrosion makes that part unbalanced and makes the machines banging around more and more as time goes, until the vibrations are unbearable and the bearing starts screaming. In my case, it made the tub seal scrub against the spinning arm and started smoking during the final spin.
Guy at the part shop suggested to use warm water at all time to extent the life of the spider arm, as well as leaving the door open at all time when not in use, to keep the parts dry inside.
Here are some pictures I took in the process of replacing the spider arm. The thing was so badly corroded that it completely fell apart in dust when I removed it. (Good thing I did this in my garage…).
I paid ~ 170$ CAD for the replacement spider arm, which is completely worth it for a 1200+$ Kenmore Machine that is only 7 years old. It’s now running smoothly and I expect at least another 8 to 10 years without this to fail again, with better care this time!
I hear you about the costs and energy of using warm water. But I like to keep my appliances for a long time. I don’t want to calculate the costs and energy of replacing entire washing machines every 5 to 10 years!
Stabilize your Washer or Dryer for Good with Steady Spin!
This is the first and only washing machine stabilizer that works from the TOP of the machineNOT the bottom!
Better still, no lifting or moving your machine involved saving your machine, floors and if flat living…your neighbours. It is like hiring someone to sit on your machine 24/7.The right size, the right pressure and the right pump to do it!So easy to install, just slip the vinyl bladder between your machine and countertop then inflate to a snug fit with the handy manual pump, which can be hidden away so you can’t see it. The appliance, now stable during the most ferocious spin cycles absorbs energy reduces noise while ensuring no movement or jumping for the whole wash. Your ears, floors, machine and neighbours will thank you for it! Invented in the UK in 2016
ORDER FROM WWW.STEADYSPIN.CO.UK JUST £15.95 inc. P&P FOR USA orders go to steadyspinusa.com
Thank You so very much!!! I’ll definitely tell my husband!! We’re seniors citizens and everything that my husband was able to do in years past he’s unable. But, my son visits us every two weeks, so he’ll have a chore !!?
banging could it be the sring tubis laying off blance
My machine bangs every time its in the spin cycle please can anyone help me with this before i throw it out the door
My machine bangs loudly while spinning and the machine though has been brought for over nine years but was never used, so it's practically new. What should I do. The make is Hoover.
I took the lower front panel off and taped down the safety switch on the right. When I ran the machine and got the knocking sound during the spin cycle, I pushed (with a stick of wood) on the outer tub (which does not spin), and the knock went away completely. I didn’t have to push hard. So I put a small spring from the top of the left front damper to an existing hole in the cabinet front, and that solved the problem. I presume that there is backlash (looseness) in one of the tub support somewhere, and the spring keeps the backlash from banging. Been working fine now for a month.
My mechine as devloped a loud noise from the inside the tub it sounds like a plastic cap thats being thrown around the inside tub whats the chance some large foreign object is in theis.and if so how do i get it out ..
This is what mine is doing did you find out what it was
Sounds like something is bouncing around inside but there's nothing inside the close tub. it's the spindle assbmly between the inner and outer tubs
My washer was resonating the drain hose during the spin cycle.
It was vibrating against the inside wall of the washer causing a really loud repetitive noise.
I opened the back panel and duct taped the hose to the inside wall and it fixed the problem.
I have the loud sound when spinning. My Kenmore is only 5 years old, very upsetting! I had a repairman come out, said it was a bearing, cheaper to buy a new machine! Cost me his service call, $70! I’m literally SICK about this having to purchase a new machine.
The fix that I described in my post above, dated 10/14/18 is still working perfectly after 2-1/2 years. Our Kenmore , purchased 18 years ago in 2003, is still purring like a kitten, just like it did when it was new. It made a loud rapping sound during spin cycles for 10 years before I figured out how to fix it, so no permanent damage was done.
Note that I also separately “leveled” my machine, but that term is a gross misnomer, at best. What is really important is making sure that all four legs are pressing on the ground with about the same force. I call that “balancing” the machine. Here’s how to do that, with the machine not running:
(1) Stand in front of the machine and try to rock it back and forth by pushing it digonally, say from the left front leg towards the back left leg. Note the amount of rocking you get.
(2) Perform the same test on the other diagonal direction. If there’s more rocking in this direction, lengthen the front left leg adjustment a turn or so. If there’s more rocking in Step(1) lenghten the right front leg.
(3) Repeat Steps (1) and (2) until the machine rocks equally no matter which diagonal direction is pushed. Done!
(4) Now run a spin cycle, and the machine should be much more stable.
Note that I did not place a level on the machine to make sure it was “level”. If it looks grossly tilted you can correct that if you want, but be sure to run Steps () to (4) afterwards. That’s the key to a smooth running machine. Note that floors, themselves are not always flat. If the machine walks a bit to a new location, you may have to repeat the balancing process.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 100
Tutti i Tempi: 497,307
21 Commenti
I discovered that my drum is loose,have to open the outer tub to check
if the screw holes is ok or why it's loose.It was the spin basket aluminium part holding basket with bearing shaft.Why after 5 years this part aluminium was eaten by washing detergents which deposit was inside aluminium cast.whole part is only sold with basket for $489?? nice job Kenmore
da kanadol48
shaft has three arms holding basket or drum when the arm is broken you get big noise I can fix it but need aluminium welding or scrap washing machine to replace basket but before need a lot of cleaning and protective paint on arms to have no contact with detergent
da walter
Amana Washer 4700 series have ( four plastic knuckels) that hold the four tub tension balancing rods. When one of them breaks the tub will wobble on the slightest load of clothes. Appears to be poor design feature. The plastic pieces can be gotten on E-Bay cheap. be careful to distribute the clothes evenly when you wash. Stay near the washer when you wash in case of other failures is a good practice.
da billstrachan
My machine does this also, but it is a Whirlpool Cabrio machine. I can't figure out how to open it and check the arms/knuckles, etc. holding the basket. I did notice when I remove heavier articles, such as towels, I can get it to stop. However, I'd sort of like to have clean towels too. Is there a trick to opening it?
da FixItMommy
My washing machine drum on spin cycle is banging against the door making a very loud knocking noise. Have you any ideal what it can be.
da Mark Milton
Mostra altri 16 commenti
