Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2519 Domande Visualizza tutte
iPhone 5 Water Damage/Service Unavailable Error
I dropped my Iphone 5 in water and now says service unavailable.Is there anyway to fix it, everything works except says service unavailable.
Questa è una buona domanda?
Punteggio -1
1 Commento
What have you done this far?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The first thing you need to do is either bust out the tool kit or take it to a repair shop that can tear it all apart and clean the board. I've personally worked on hundreds of water damaged iphones and the motherboard will start forming corrosion almost immediately. This corrosion will get worse to a certain point and can corrode components off the board and make it stop working or develop more issues.
This corrosion will block circuits and damaged components. So its possible the cleaning of the board will resolve all issues. Its also possible it will not, and you may need a replacement antenna or other component to fully resolve.
Hope this helps!
Punteggio 1
1 Commento:
What do you use to clean the main board? A friend gave me his iphone to try and make it work after he accidentally fell into a pool.
da
Aggiungi la tua risposta
ABarnes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 293
