Working digitizer not responsive after disassembly
Hello guys,
I just disassembled my iPhone 5 in order to replace the audio buttons.
After reassembly, the LCD works fine, all buttons as well except the digitizer.
The screen is completely unresponsive.
I am sur i reconnected the digitizer properly and took extra-care of the ribbons. What surprises me is that the full touch area is not working, not even a single dot. That's why i assume the digitizer is not necessarily broken.
Could it be linked with another component that i forgot to plug properly ? Any other idea would be greatly appreciated.
EDIT: I just tested my screen on another iPhone 5, the digitizer works like a charm ! Then the problem really comes from the rebuilding of the iPhone. The connector for the digitalizer on the motherboard doesn't seem to have had any kind of damage. (Around it as well)
Thanks in advance
Questa è una buona domanda?
3 Commenti
Check black rubber type material on motherboard around connector. Carefully remove it and new plug should stay connected.
da Victor Sponheimer
Hi, had the same issue. I re-tighten the screws connecting the the metal shield to the back of the screen,,, for good earthing and all is well
da Welcome
Hi there, so I think I might have the solution.
The screen obviously has the three black ribbons that end in the connectors that need to be connected to the iPhone.
You automatically start with connecting the connector for the digitiser as it is the one that must be connected first, because the other ribbons go on top of this connector.
What I did - and what I would recommend you doing- is to buy a piece of double sided tape (this exact kind https://imgur.com/a/q9jgwca) and put it on top on the back of the connector for the digitiser so that the ribbon from the other two connectors push down onto the tape and therefore onto the digitiser connector. That way there is constant pressure. (for those of you who don't click on the link - it is the kind of double sided tape that has some thickness to it).
Worked like a charm for me.
da weinhonig
