Salta al contenuto principale
Smaller, thinner, quieter model of the Playstation 2 (SCPH-700xx) released by Sony in September, 2004.
89 Domande Visualizza tutte
laser lens for playstation 2 won't stop loading forward and won't read
when you turn it on the tray that the laser lens sits on keeps loading forward past its stopping point. it keeps clicking and won't stop loading forward therfore it wont load any games. any suggestions on what it could be and if so will it be fairly easy to fix? the playstation i have is the new one not the old big ones but one of the real thin ones. please help thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your system is a PSTwo, not a PS2.
Check to see if the sensor on the PSTwo laser is broken off, or stuck down or up. It's a tiny black nub on the surface of the laser closest to the transport (disc spinning motor). It's supposed to freely push in and pop back out. It's easy to make it stuck if a sticky liquid gets in there.
Good Luck.
Punteggio 1
2 Commenti:
it seems good with mine, yet the issue remains
da
I had this issue and was able to fix it. I had to take apart the spindle assembly and resolder the sensor button. The solder was very dull so my only guess is it wasn’t making good contact with the board.
da
Aggiungi la tua risposta
chris mccalister sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 20
Tutti i Tempi: 4,619
