Salta al contenuto principale
Modello A1286. Lanciato nel febbraio 2011 / processori quad-core Intel Core i7 da 2,0, 2,2 o 2,3 GHz
586 Domande Visualizza tutte
Broke the welded subowoofer connector
While I was replacing my optical drive by a second hard drive, I unfortunately completely disconnected the subwoofer and left speaker connector, even the little part which was welded to the logic board.
As a result, only my right speaker is functional.
I don't know if I can repair it on my own, as it involve re-welding a component.
Does I have to buy a new subwoofer and/or a new logic board ?
Questa è una buona domanda?
Punteggio -1
2 Commenti
Hi, have the same problem
Is it possible just to glue socket to the board and align contacts?
Thanks
da
Hello,
I have the same problem... Did you fixed it?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Mourad, this will depend on your damage. If the traces are damaged it'll be difficult to solder. Any of the soldering to the board should be done with the right tools and the right knowledge. Post an image with your question that shows the damaged pieces for a better answer.
Punteggio 2
It's possible
You can try, but I would recommend a new logic board. However, if you still have 1 functional speaker, why not just keep that? By the way, it's called "solder", not "weld"
Punteggio 0
Aggiungi la tua risposta
Mourad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 156
