Salta al contenuto principale
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
103 Domande Visualizza tutte
Why won't the TV recognize my N64?
Hi! I was feeling pretty nostalgic recently and got an N64. It worked for a few plays, but I've been trouble recently. The N64 turns on just fine, but the TV won't recognize it---it gives me a "no input" error.
I thought it might just be AV cables going bad (they were pretty old) so I replaced those, but no dice.
I did just get an expansion pack to play Majora's Mask, but it worked after that for about one play. Since then it hasn't.
I've tried different ports to make sure I have the AV cables in the proper place, and nothing appears to help. I've plugged it into TVs not connected to satellite, I've disconnected other gaming devices, I've tried everything I can think of. Does anyone have any suggestions?
i've tried it on multiple television sets, by the way, in different households.
Questa è una buona domanda?
Punteggio 1
1 Commento
Probably logic board failure. I would recommend getting a new one.
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Rachel, hope it has worked on the newer TV's before. Anyhow, I would suggest that you clean the cartridge slot first, follow this guide. After that, it is time to open up your console, use this guide, and check for any obvious signs of burned or loose connections. Check for broken solder contacts near the power switch and near where the power pack plugs in. If you are handy with a multimeter, I think I even have some schematics for this console. Hope that helps, good luck.
Immagine Nintendo 64
Guida
Come pulire l'alloggiamento della Cartuccia del Nintendo 64
Difficoltà:
Molto facile
5 minutes
Immagine Nintendo 64 Motherboard
Guida
Nintendo 64 Motherboard Replacement
Difficoltà:
Facile
15 - 20 minutes
Punteggio 2
Aggiungi la tua risposta
Rachel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 28
Tutti i Tempi: 7,107
