Salta al contenuto principale
Also known as the LG Splendor, an incarnation of the LG Optimus L7, sometimes known as the LG Snapshot or Swift L7 under the model numbers US730 and LG730 depending on carrier.
I can't find a guide to replace screen
I've been searching all over YouTube and a couple of websites but i cant seem to find a guide for the LG Venice/Splendor, I've seen similar phones that LG manufactures which have the same repair steps, would this phone file under other phones in means of repair guides?
Questa è una buona domanda?
Punteggio 1
2 Commenti
Much thanks :) i really appreciate the guide and response time thanks again :D
da
you are welcome. Best of luck to you and thank you for accepting my answer.
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
alcranking, try this:"
Take apart the battery cover using notch below
Take apart the battery and remove screw (12 point)
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
3. Remover the Bracket Camera to upper
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
I always wonder about the grammar in service manuals :-) Hope this helps, good luck.
Punteggio 4
4 Commenti:
So this is a screen replacement guide for the LG Venice? Please correct me if I am wrong.
da
Jabran, yes it is
da
Hey old turkey, I am grateful of the pics you put up to fix the lg Venice, but could you please make a video, because I cannot understand the pics that we'll. if you could send me the video on my email that would be great. Husban_shahid_7@hotmail.com
da
Sorry Husban., I did finish the repair and do not have the phone anymore.
da
Okay I follow just didnt remove the lcd I simply replaced the outer screen now I keep getting this black smudge on my screen do I have to remove the lcd or do I use loca
Punteggio 1
9 Commenti:
depends on "the smudge", post an image and let us see what you see.
da
https://dl.dropboxusercontent.com/u/5441...
Here's a link to the images and no its not water don't know what it is when I go to remove everything to remove the screen it goes away
da
"when I go to remove everything to remove the screen it goes away" what exactly do you mean by the? right now it looks like air trapped between the digitizer and/or LCD.
da
When I go to seperate the frame from the back piece to get to the screen I guess it could be air
da
It does look like it creates a bubble underneath,
da
Mostra altri 4 commenti
Thank You :)
One more question: Do you recommend exchange by my self, or go truth an specialist. looks not complicated but I do know nothing about cellphones. looks like is just the glass screen broken but since this was broken because I press with the trunk of my car:( I do know if can be there another damage.
The other hand, I find a different options to by a screen replacement, since screen glass to digitizer and complete screen digitizer assembly? could be the last one a best option...I appreciate any tip to do it or not risk. Because I really want back my cellphone for personal reasons.
Thank You.
Punteggio 0
1 Commento:
Replacing the LCD will not affect your memory.
da
Aggiungi la tua risposta
alacranking sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 6,993
