My screen is on but the not responsive
I changed a cracked, the ipod powers up with picture but the screen will not respond.
Questa è una buona domanda?
nathanlinville, double check your work to make sure your connectors are properly seated. If the connector is okay, properly seated and no bend or broken pins, I would replace the assembly once more for a new one. If you find that the assembly is working, just not in your iPod, you may have a faulty touch screen controller on the logic board. Check for missing, charred or broken parts on the board. Hope this helps, good luck.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 155
