Salta al contenuto principale
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Domande Visualizza tutte
Bulging battery problem, won't turn on
My iPhone battery started to bulge after it had been dropped and the screen cracked. The battery has been taken out and replaced and the screen replaced however to phone will not come on. I plugged it into the charger and It flashed on then went off and it will now not come on. Do you think it could just be a faulty battery or another problem?
Thank you
Rachel
Questa è una buona domanda?
Punteggio -1
1 Commento
You are using a new battery, correct?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The new battery could be defective. Try replacing it again.
Punteggio 0
Aggiungi la tua risposta
Rachel craigmyle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 278
