Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
System crashes constantly. New ram and hdd didn't fix
System constantly crashes. Replaced ram and upgraded to new hard drive. Still no change. All software up to date. Tried reinstalling mountain lion OS X and with 6 minutes left on install it restarts and tries to install again. Now stuck in an install crash install loop. Help
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
This is a problem of Logic board . In this Logic board nvidia stopped working due to this system crashing again and again even reinstall the OS X. Visit the apple service centre for the replacement of the Logic Board . They will provide you a free replacement if Nvidia fails. After replacement you will get the 90 Days service Warranty of Logic Board only. They will run the VST test on this MacBook . 99.9% this is problem of Nvidia. If tech said this is not a problem of nvidia tell them to run the VST test. VST test is only support MacBook Pro 15inch MID 2010. Good Luck
Check this Article:
http://support.apple.com/kb/TS4088
Punteggio 0
Aggiungi la tua risposta
Matt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 686
