Antenna Switch PCB on Motherboard
How to exchange the Antenna Switch PCB on the Motherboard?
This is soldered or glued?
Questa è una buona domanda?
joerg, if you are talking about the Antenna Signal Module also called ""cellular Interconnection Flex, cable" than yes, it is solder. A good soldering iron with a fine tip, and good skills are a must for this. Hope this helps, good luck.
Any link for part ? Nothing on ebay as I can tell ?
will this work for iphone 5c?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,292
