Salta al contenuto principale
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
Why isn't the power/lock button working?
When I plug my phone into the charger I can use it when the screen lights up, but when I unplug it and the screen goes black I can't. The power/lock button is not working.
Questa è una buona domanda?
Punteggio 13
3 Commenti
Does it feel like the button is clicking? Was there any exposure to water?
da
Yes due to rain my phone get wet. From then it stop working.
da
Unfortunately, the Droid RAZR is quite sensitive to water. droplets touching the fingerprint reader will be detected as fingerprint-read-failures when the screen is off, and if it is on, drops will just turn the display off.
Also, if ANY water gets into the side power button, that button will remain FLAKY for several hours afterwards (until it fully dries). You can help it by drying it as much as you can (gently tapping the phone on its side onto a towel)... I left my phone on the dashboard of my car for about an hour once and that did the trick (the heat from the sun).
da
Aggiungi un commento
20 Risposte
Soluzione Prescelta
I had the same exact problem today! I called Technical Support and talked to a very helpful woman! She explained to me that sometimes your phone needs to "reboot" itself. To reboot the phone, I just held down the power/lock screen button, and the volume down button for about a minute. The phone then restarts and gives you the power up screen. Now my phone is back to normal, and I can unlock the phone without it needing to be plugged into the charger!
Punteggio 14
15 Commenti:
Jessie,
Thank you so very much for sharing the instructions Tech support gave you! It worked perfectly on my phone!
da
Worked for me too, thanks a ton!!!
da
Dude jessie thanks man.
da
I've been able to reboot my phone three times using the instructions above (which would make me believe that the lock button is still working to some extent), but the lock button still doesn't work to lock/unlock the phone :(
Looks like I'll be on the phone with Verizon support.
da
Update: I rebooted my phone 3 times as stated above, then performed the dreaded "factory reset" as a last ditch resort. Unfortunately, that didn't work either so I called verizon customer service. They're sending me a replacement phone, overnight shipping, free of charge. My phone is approximately 1.5 years old, so I'm pumped that they're covering it and not making me wait until I qualify for an upgrade.
da
Mostra altri 10 commenti
TRY THIS!! Alright so for anyone that this DIDN'T WORK: I had this same problem, but it wasn't that big of a deal until my phone DIED. Without a power button, there was no way to turn my phone on. Well after charging my phone until it had a full battery, I then took my charger cord and plugged it into my laptop... tada! It booted right up, and has done that a couple times since, so all in all it's an easy fix getting it back on, even without the power button functioning at all. Hope this helps some of the rest of you!
Punteggio 3
3 Commenti:
THIS WORKED for me! Like immediately. Oh my gosh, thank you.
da
but after holding the volume down button and connecting the phone in to usb its just give me options to start or recovery and some other options....now the problem is the option can be choose by clicking power button...volume buttons are just working for scrolling the options... help plz...
da
did not work I changed the battery on my moto x pure edtion and the power butten and sound button don't work it charges and when you plug it in it turns on but only shows gnat it is charging what should I do
da
Could be, but maybe a drop that you are/are not aware of? I would recommend a simple visit to your nearest repair shop. You may have a restriction set that you are also not aware of, so have a look in all of the obvious places where this could be.
Punteggio 1
Worked for me too, Thanks
Punteggio 1
That worked just fine for me. Contacted Verizon, the rep said no problems of this nature have been reported and immediately issued a replacement phone. This happened about 5 minutes into my beginning work and I do not have internet access so I said send the phone. When I got home to my laptop I googled the issue, found this page and fixed my problem in about three minutes. The phone is working much better than the customer service rep at Verizon worked tonight. Shame on you Verizon for allowing such a lazy employee to deal with your customers.
I did just what was described and my phone is working fine. The replacement "refurbished" phone will be returned to sender!!!! Thank you so much for sharing your information
Gary
Punteggio 1
I just had the same issue with my phone, my power button wasn't working. I thought I was going to have to take it to a store tomorrow to see if they could fix it. I got on the computer and googled the issue and found this solution. Thank you so much my phone is now working great, power button and all. I would hate to have gone in the store and looked like an idiot just to do this. LOL Thank you so much for your help.
Jeremy
Punteggio 1
I tried to reboot as well and it didn't work I did drop it in the toilet this morning for about a second bit its on everything works except the power button any other suggestions? Thanks
Thad
Punteggio 1
my phone wont let me unlock it and the power button and volume button arent working, any ideas how I can restart it?
Punteggio 1
JESSIE!!! Thank you!! I thought I was going to have to buy a new phone! Even the international Motorola customer service gang didn't know what to do! So Yay to Google for providing me the link to your answer!
Punteggio 1
That just worked like magic for me. Guys you made my day.
Punteggio 1
Worked for me also.Thanks a lot
Punteggio 1
I'm having this exact same problem I've tryed the power button and volume button reboot but it didn't work any other ideas on how to get my power/locking button to work?
Punteggio 1
1 Commento:
did you ever fix your phones issues?
da
My Droid Ultra (XT1080) power button completely broke. I read a few replies to questions about the same issue in a couple different places, and the above did NOT work for me, however, the option that DID work, was - at the SAME TIME - I plugged in my charger (after letting it charge to about 13%) I pressed the volume down key, and immediately the boot screen popped up, giving me options, Factory Reset being the option immediately highlighted halfway down the list. From there the volume Up key makes the selection, and you can scroll thru the options using the volume Down key. Hope this helps! :)
Punteggio 1
worked for me as well...
Punteggio 1
My huawei Y6 power button and lower volume are not working. Today is exactly 2 weeks from the time I bought it. What could have caused this?
Punteggio 1
My moto z2 will reboot if it gets slightly wet (rain, shower). Only a few drops will cause it to happen. When it reboots, the pool were button no longer works. If I then add a moto mod, like wireless charging, the fingerprint/ home button also will not work until I remove it. Then the home button works again. But a few hours later, both work again. I suspect water is causing the power button to “close”, main the phone think you are holding it down. Later it dries and is ok again
Punteggio 1
this did not work and I don’t have a computer with a usb plz help
Punteggio 1
did you take a pet your phone cause the springs might have fallen out
Punteggio 0
My power button isn't working all the way on my Moto z3. I suspect water may have reached it the day before when it was near the sink, and heavy rain that day. Random things keep going wrong with my phone, ex: doesn't recognize SIM card, my phone would restart nonstop, and now the power button. I fixed the SIM card issue by powering off my phone, and the restart issue by bringing my phone to the reboot screen. My phone has a finger print censor so I wasn't too worried about the whole power button thing when it came to turning my phone on, but turning it off is an issue. If I hold the button down, the regular options come on (power off, restart, screenshot), but one simple push on the button doesn't seem to do anything, though it does work occasionally.
Punteggio 0
the volume down button is not working due to which my Motorola one power is switching on and off by itself and not other functions can be performed on it . what do i do ?
Punteggio 0
Aggiungi la tua risposta
Bradley sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 150
Tutti i Tempi: 82,814
