Ruined screw (5 Point Star Pentalobe screw)
my macbook 5 point screw is ruined and i cant get it out !!!!!!! What to do I do HELP ME
Questa è una buona domanda?
For screws that I can't get to the head, I use these Precision Screw Extractor Set: Precision Screw Extractor Set
For screws where I can get to the edges of the screw, I use these Screw Extracting Pliers: Screw Extracting Pliers
For the screw you messed up, I use the correct tool, MacBook Pro and Air 5-Point Pentalobe Screwdriver
Prodotto
$5.99
Prodotto
$24.99
Prodotto
$19.99
Follow the answers from the tags on the right. You'll need access to an easy-out, a small drill or dremel tool. Every DIY job is easier when you use the proper tools.
If this answer was helpful please remember to mark it accepted.
The easiest and cheapest way is to cut a very small piece of aluminium foil from your kitchen roll, and loosely put it onto the screw, then use a similar size normal flat blade screwdriver to unscrew the ruined one out.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 9,462
