Salta al contenuto principale
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Domande Visualizza tutte
Domanda Chiusa
Why is the expresso shots not hot?
Expresso shots not hot mach says select beverage heater? How do we do that?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
What temperature are your shots coming out at? To accurately measure this you need to place an instant-read digital thermometer directly in the stream of water coming from the brewhead (leave the portafilter off); temperature should be around 200 F. If considerably cooler you may have calcium buildup in your boiler that's preventing the machine from heating properly, and in that case you should descale it with Durgol or other citric acid-based descaling agent.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 288
