Salta al contenuto principale
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
201 Domande Visualizza tutte
Domanda Chiusa
s2 not charging battery to 100%
S2 battery holder jack inside battery chamber.. Showing open circuit voltage..4.16only..no over heating any where...i hve already replaced usb flex ..bt same problem ...
On charging ..while m running heavy application ..battery goes down
Max battery charge voltage(closed circuit)4.012
Battery charger is ok... Nd delivering 5 volt on mother board
S2 model is i9100G
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
I do believe that if you push these these phones hard enough, you can actually drain the battery even if you have it plugged in and "charging." I know one of my buddies did it downloading and gaming at the same one before. 4.16volts is kinda high for a 3.7 volt battery though. I've seen mine max at roughly 4.02 volts, but that's on a Galaxy S2 Skyrocket.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,721
