Fan only works on high
Hello,
My fan switch only works on high so I know it is not the motor but probably the switch. But I do not know how to remove the dash cover to get to the switch. Do I have to take the entire dashboard off? Or is there a simplier way to access the switch. This would help me to replace the lighter plug that has not worked for 10 years. It is a 2001 Camry LE.
thank you
corey
Update
Thank you very much for your help. It makes sense that the resistor is out and therefore the blower only works at high speed. I will trace the wiring back to the resistor.
One questions though, how do I remove the center counsol to get to the blower? It seems like the entire cover is attached to the dashboard so I hope I do not have to remove the entire dashboard. Is there a key screw to remove that allows the cover plate to be remove to expose the blower?
thank you again for your help.
corey
Questa è una buona domanda?
