printer suddenly has no power
My Canon Pixma PM610 after having printed one page suddenly had no power to print second page. no reaction at all. Check of cable, socket etc. was ok. Canon told me "thats the board, cost 150.-Euro. Doesn`t pay. Buy a new Printer". Is this true? Have I to throw away my printer. I will miss the top scanner (9600x4800 dpi). Any idea how I can bring back my printer to use?
Thanks all
Peter in Berlin
Questa è una buona domanda?
3 Commenti
If your printer has suddenly no power supply then check out for the internal and external power supply. Also, first you disconnect them and then again connect the printers.
da Richard Simpson
I would be grateful if you could give me an idea on accessing the printed circuit board please.
Best wishes,
Peter
da peterwilko99
I have the same problem with a Canon ip6700D, which is likely to be similar to the PM610. One pro fixer says the programmable zener on the power boards goes frequently, but mine was OK. Now looking to pull down the printer and look for other hidden? fuses.
Getting at the PSU: The security screws are plastic and look like they are install only, and disintegrate on removal. YMMV. Ream them out brutally. You might be lucky with the right security driver. 2 plastic catches and the PSU pops out A further single metal security screw secures the lid. BE CAREFUL. - EXPOSED MAINS.
In mine, fuse 3 was blown. (different fuse numbers on different models) but check them all.
The SMT components are really close together, so if it isn't a fuse, the regulator or the switching MOSFET then a new printer gives least frustration. These printers are not meant to be repaired, and I understand a new PSU (probably no longer available anyway) is in the same order of cost as a new printer.
Good luck (and to anyone else with similar issue)
da PAF
