The sound is messed up
it sounds like the headphones are not plugged in all the way but they are. You can hear the music but not the words
Questa è una buona domanda?
is digital it should be all or nothing... are you listening to a karaoke or instrumental track?
Remember to return and mark as accepted the answer that best solves your problem.
Good luck,
N
clean the jack. you can also try to use a very fine screwdriver or similar tool to carefully bend the outer connection a bit towards the plug...
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,448
