3ds turns off when opened fully or too fast
3ds turns off completely when opened
Questa è una buona domanda?
I've not seen this issue on the 3DS yet, but on the DS Lite sometimes the cable to the top LCD could be loose and result in the behavior you described. As someone else said it could be short (i.e. a broken cable) but I think it's more likely just loose. Check where the cable plugs into the motherboard.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,657
that happens to me too!
da sonicdahedgie
Have you tired to disassemble it by using the guides? Check your ribbon cable, it sounds like it is shortening the 3DS out. Unless you take a look at it, it is all just a guess.
da oldturkey03
