Salta al contenuto principale
Guide per lo smontaggio e la riparazione dei computer Macintosh di Apple.
42746 Domande Visualizza tutte
Domanda Chiusa
Spilled coke on keyboard
Spilled coke on keyboard on the right side.
Right Shift, Delete and some other keys on the extreme right got sticky. Cleaned them, but still no function.
On-off key is ok.,
How can I figure out what's is damage by the coke.
The Battery or other components.
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You'll have to open the machine. Inspect and clean the wet/sticky parts. Use the tags on the right to see what you're in for. If there still was liquid between the key and the keyboard when applied power you might have permanently damaged it, in which case replacing the keyboard or top case is where you'll have to start.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 404
