Salta al contenuto principale
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
405 Domande Visualizza tutte
Domanda Chiusa
Dvd and SD card In the DVD rom
Hi
In the dark i mistakenly inserted my sd card to the cd room and when i was trying to take it out it went more inside and not visible anymore, I did another wrong thing after that which is that put a dvd after that and now the dvd wont even eject nor show up in the computer..
What is the best option for me
Either change the drive or any way to take the memory card and dvd out of the drive..
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes - you'll want to follow the guide for your machine (using the proper tools- every job is easier when you use the right tools) open the machine, remove the optical drive, remove the cover from the optical drive, remove the stuck/foreign parts, and (partially) reassemble (don't screw the unit completely together) until you see if you've damaged/destroyed the optical drive (chances are good that you have). In which case order a replacement optical drive or SSD drive kit, reassemble and test before completely screwing everything down tight.
If this answer is acceptable please remember to return and mark it.
Punteggio 1
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 194
