WiFi Connector Broke While Removing Wif Card
Hi i broke my wifi card connecter while trying to remove the wifi card can you please take a look at the pics and tell me if i can remove the rest of the bit somehow ?
Update
Dude the nylon spudger tip keeps breaking on me... i have used 3 spudgers and they all have failed as the area is so small the tip has to be perfectly sharp as any little correction to the tip then it don't fit in there.... Also i did mange to get it up from the right side but the problem is the left side is fully filled so the right side only lifts ever so slightly its really hard ? Thanks
Update
Awesome Dude i used a compass as those nylon spudgers kept breaking job done i manage to remove the reminder of the connector :) Now my only problem is the wifi card i order was the right one but the connector cable that connects from wifi to the mother board is too long so my question is where can i get one from ? Also what is it called i know its a dumb question i have attached a pic with this post Thanks
Update
Questa è una buona domanda?
4 Commenti
what is the name of this part in the logic board ( WiFi ) if i would like to buy online.
any idea. I lost mine . it was broken too
da Kamran Chowdhury
@Kamran Chowdhury hey dude what year is your MacBook Pro ? And whats the model number ? that part is simple to track down mine was A1286 Wi Fi Card... it will come on a card remove the screws and install on the old one you took out, well that's how my process was :)
da TH3ORY
@TH3ORY
no i am talking about the 1st picture. WIFi component in the Logic board beside the DVD drive came off. i lost that part. You can't screw it. it need to be soldered. mine is Mid 2012 macbook pro 15
da Kamran Chowdhury
@Kamran Chowdhury Dude that's going to be super hard to get.. i doubt it very much you can purchase it on it's own, unless you find a Mac specialist other then Apple.. you could try ebay get the whole logic board or try alibaba tons of Chinese suppliers on there they might be able to help Good Luck Dude!
da TH3ORY
