Can I put more than 4gb RAM into my MacBook?
Is it possible to put more than 4gb into my MacBook Unibody?
Questa è una buona domanda?
Apple says 4 GB but Mactracker says you can install 8 GB of ram. Ralph
This assumes your computer really is a Model A1342 Ralph
Here is a URL for the memory capabilities for all Macs. Ralph
agreed +
but be careful! If apple finds out they void the warranty! and yes the max is 8gb
but if you get caught with more then 4gb they void the warranty
Where is your proof that Apple will cancel the warranty? Ralph
I don't believe Apple voids the warranty for a RAM upgrade on this machine.
if you go over they do
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 11,786
2 Commenti
On the MacBook models this is going to be a 4gb maximum for any model in the past year. The ones with the 8gb max are the MacBook Pro models.
da Xen
On the chart I referenced it shows the MacBook unibody with 2.26 Ghz and awhite plastic enclosure as being able to use 8GB ram. If that is not the OP's computer he should check the chart for his max ram. Ralph
da rj713
