Salta al contenuto principale
Won't power up all the time
I have been handed an 06 15" Pro with the C2D 2.16
The problem I'm having is that if I have the battery installed (fully charged) it won't power up. Not even the slightest indication of working, IE no fans, lights, hdd, dvd nada.
I'll connect the wall charger and I get a dim green light, dim amber if the battery is in need of charging.
Remove the battery and plug in the charger a couple of times and it goes to bright green (dim green till then) and act's like nothing was wrong. Boots right up, runs great and when I install the battery while it is still on it shows up. It will charge it if it is low. I can then pull the wall charger and it will run fine off the battery.
I can even shut down and restart off the battery if I don't let it sit too long.
I have checked the battery on another system and it works fine. Used another battery on this one and it has the same problem.
Charger is working fine on all machines and used others on this one with same results.
I did find out that if this one won't power up (battery installed) and I get the dim green light and then use the charger on another machine first it will then go right to bright green when I reconnect it to this one.
I am using the troubled one as I type, have done all the tests and reset everything I can think of (please don't tell me to do the basic things like pram, check/clean connections and such, it has been done to death) but have not run into anyone else that has seen this problem.
One last thing I noticed is when I do shut it down I get the spinning cartwheel for a short time then it shuts off.
Any idea's?
Update (10/21/2013)
Ended up replacing the hard drive and the power board, hard drive (Seagate) took way to much power to fire it up even in a newer machine and the power board I am guessing became weak from it.
Questa è una buona domanda?
Punteggio 0
3 Commenti
It says I am at 98% charge and have 46% capacity
Like I said, have used another known good battery and it did the same thing.
It seems that with the battery in it won't power up and the charger won't go to bright green unless I use the charger on another unit and then switch it to this one.
Once it has started everything is fine, not on the wall charger right now.
Wondering if there is a capacitor or diode that is on the fritz and takes just too much power when the battery is in to light it up.
With the battery out the wall charger will go to bright green right off as long as I didn't have the battery in beforehand.
I am using 85 watt chargers and they are all working great.
da
So I have yet to get this to work right and it is getting a little worse.
It takes several attempts of connecting the charger to the unit before it turns bright green and even then it won't all ways power on.
I'm leaning on the logic board having a problem as the I/O board tested fine.
I used a new battery that I borrowed and the unit still wouldn't power up with it but ran fine once it was going.
Odd little bugger
da
46% capacity on first 95% on second
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
The battery may be charging to 100% of its current capacity, but the current capacity may be very low. This machine will not start most of the time if the battery is below 20%. To find out download and run Coconut Battery: http://www.coconut-flavour.com/coconutba...
Please let us know what you find.
Punteggio 2
3 Commenti:
What did Coconut battery show?
da
First battery 98 charge 46 capacity, second 100 charge 95 capacity
da
Is that a 98% charge and a 4600 capacity?
da
Aggiungi la tua risposta
Dana sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 367
