Salta al contenuto principale
iMac è la linea di computer desktop Apple all-in-one.
8402 Domande Visualizza tutte
Cleaning the Mac's innards when you are replacing the HD
Plan to exchange original HD for 2TB one. When at it, noticed quite some dust in/on fans and other places. Once read (do not remember where) that it is unwise to vacuumclean the innards. Why?
I have ESD-safe brushes and other gear, will mechanically block the fans (so they cannot act as windmill generator) and use the VC on its lowest powersetting and will maintain at least a 10 cm or 4 inch distance between hose-intake and innards. Still unwise?
Greetings from continental Europe.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Vacuums in-fact create a static charge! The air sucked in at the nozzle creates a mini Van de Graaff generator within the air stream between the different air pressures. - As Machead stated use Can'ed Air to blow the dust and junk away. Scrubbing with a soft artist brush (being careful not to snag any parts with the brush) to help loosen the dust is also a good idea.
Punteggio 3
Parts can be knocked, torn, or sucked off the board with careless use of a vacuum, that's why blowing is recommended. With your attention to care you should suffer no ill effects.
If this Answer is helpful please remember to return and mark it Accepted.
Punteggio 2
1 Commento:
OK and thanks for your thoughts and comments Dan and machead3.
F.H.
da
Aggiungi la tua risposta
Feike Hoogenbos sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,086
